I was wondering if it is possible to upload all files in a foldr containing like 50 text files with the same delimited format & field order as 1 TI process? I'm still tryin to get used to using TI and I'm still scope all is possible use & process.
I'd also like to know if there'a way for TI to determine like if your text file name for example are element names of 1 of your dimensions. So it can zero those items with files in the folder and and not include those elements to be zero out during TI process. Like I have countries like all Asian countries and I only Japan & Korea would be using like offline templates. So their text file would have Japan & Korea as name and I want to make sure that only these elements would be zero out.
I just want to figure it out if this is possible than manually creating the view and double checking which files have excel existing. Or is there a better approach to this, like being able to choose which files to upload only at the same time zero out that specific data point.
Uploading different text file as 1 TI process
appleglaze28
- Excel Version: 2003
Gregor Koch
- Version: 9.0 and up
- Excel Version: 2007 and up
Re: Uploading different textile as 1 TI process
Yes, this can be done as everything in the prolog tab is executed before you hit the data source.
1. You could create a process which cycles through the file names and executes the actual load process with the filename as parameter
While there are ways of using ExecuteCommand and batch files to create a list of files in a folder you can also cycle through the files by using the function WildcardFileSearch( Pathname, PriorFilename);
Below is an untested quick example for the process which cycles through the files.
2. Your load process needs to reassign the source name with the function
DatasourceNameForServer='Name';
which in this case would be equal to the parameter pDataSource.
Hope this helps and is not too confusing.
sLastFile='';
iFile=1;
WHILE(iFile<=50);
sFilePath='YourFilePath\';
sFileWildCard=sFilePath|'*.cma';
sFile=WildcardFileSearch(sFileWildcard, sLastfile);
IF(sFile@<>'');
ExecuteProcess('LoadProcess', 'pDataSource', sFile);
sLastFile=sFile;
ELSE;
iFile=50;
ENDIF;
iFile=iFile+1;
END;
appleglaze28
Re: Uploading different text file as 1 TI process
How do I define a Data Source Name under the Data Source tab for this scenario. I can't not define one cause I won't be able to write on the Data tab to map the dimension with the columns of my .csv file.
For the LoadProcess, do I define all parameters as if I'm uploading just 1 single file? or do I define it some other way?
So in creating the parameter pDataSource what would be the value I should input? Where does the DatasourceNameForServer='Name' come into play?
