I'm about to migrate tm1 applications to PAW. Does anyone know of any document/process to do this, how to handle the }tp objects etc.?
Rickard
Migrate tm1 applications to PAW
- Steve Rowe
Re: Migrate tm1 applications to PAW
I think you asking how to migrate the TM1 Apps Web or TM1 Applications workflow functionality to PAW Applications and Plans?
As of right now in the 2.0.9 series TM1 Apps Web should continue to work, assuming you install Performance Modeler and use the same interfaces as before.
However, if you are going to 2.1.0 (and that would make sense since 2.0.9 is being deprecated 30th April 2025) then TM1 Applications is also deprecated as per this post
You can use PAW Plans to produce similar functionality to that in TM1 Applications but I don't think it is a like for like replacement. There is no migration path AFAIK, it is brand new functionality.
