Block user in PAL
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Block user in PAL
Post by EP_explorer »
Is it possible to block user in PAL (TM1)?
I.e. user hasn't come in system 90 days and its account has to be blocked by security policy.
I don't want to delete account because may be the user will return and I have to put his account in all his groups again.
I use 5 security mode and put users from Active Director in groups using CAS portal
Re: Block user in PAL
I haven't used it in a while but there is an "IsDisabled" flag in the }ClientProperties cube.
If you put a 1 in there it should stop the user from being able to connect.
Declan
EP_explorer
OLAP Product: PAL
Version: 2.0.9
Yes
it works thank you
declanr wrote: Fri May 24, 2024 9:25 am Hi,
Declan
Yet another thing that I don't believe we have a solution for yet in PA Engine.
