If you have a dimension with brackets in it's name, say "Dim1 (Brand)" for example, how to you specify the dimension in a function as:
=N: DB("Cube1",!Dim1(Brand), ...)
You get an error if you try to do it as above. Putting quotations in won't work either. Has anybody encountered this before ?
Referring to a Dimension Name with brackets
- TheMichael
- Steve Rowe
Re: Referring to a Dimension Name with brackets
I'm guessing you can't, it's normal to avoid these kind of chracters when naming objects...My only guess would have been single quotes, if you've tried that then I can't help, not that means that there isn't answer (other than change the name of dimension and rebuild the cube!)
Yup, I thought that this one sounded familiar. Time for a dimension name change I'm afraid. See:TheMichael wrote:If you have a dimension with brackets in it's name, say "Dim1 (Brand)" for example, how to you specify the dimension in a function as:
http://applixforum.olapforums.com/viewP ... adID=12074
and
http://applixforum.olapforums.com/viewP ... adID=16870
There is the concept of putting an alias on a dimension. Never tried it but it might work. Right click on Dimension> Edit Attributes and proceed as usual.
Exercise care in attempting this; as per the links in my previous post, this has the potential to cause a server crash.Phil Maynard wrote:There is the concept of putting an alias on a dimension. Never tried it but it might work. Right click on Dimension> Edit Attributes and proceed as usual.
Admin Note: Certain post exchanges have been deleted from this thread for the sake of the tone of the Forum.
- TheMichael
Luckily it's still early in the development phase, so rebuilding is still an option.
Thanks for the help!
