Hi everyone
someday my tm1 instance cannot restart again, normally it will start up within 10 minutes, but now it cannot restart and the tm1serverlog also stop to record start-up details at particular lines.
anyone has encountered this scenario before?
Thanks!
Tm1 Instance starting up failure
- Steve Rowe
Re: Tm1 Instance starting up failure
Probably best to show the lines it is stopping at.
My best guess is that you have persistent feeders on and this is enabling fast start-up. Sometimes it will decide to rebuild the feeders which can take a v long time and you will see the log pause on these lines for long periods.
Key point is if the processor is showing activity against the server then its still active and working.
