Wildcard text searches in a TI process
M1ndbender
Version: 2.0.0
Excel Version: 365
Post by M1ndbender »
Hi gurus,
Is there a way to do wildcard search in a TI process?
If (element like Rad*)
Any help as always is appreciated
Re: Wildcard text searches in a TI process
No, Like does not exist.
You would use Subst. Whether it’s easy or straightforward to have the same logic is a different matter.
You could also think about adding elements to a dimension, which is not used in a cube. Then use MDX Tm1FilterbyPattern for wildcards ? and *
I have seen someone support some types of regular expressions in TM1, but admittedly it’s not a walk in the park.
You could also call scripts like Python or VbScript or PowerShell or similar, with more advanced logic. For example, to do regular expressions.
M1ndbender
Version: 2.0.0
Excel Version: 365
thank you
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Post by Michel Zijlema »
Not really a full wildcard search functionality, but for your example you could look at the SCAN function:
F.i. SCAN('Rad', 'Radius') returns 1, meaning that the string 'Radius' starts with the substring 'Rad'.
If the function returns 0 the substring is not found in the string. If the return value is > 1 than the string contains the substring, but not at the starting position of the string.
Note that the SCAN function is case sensitive.
M1ndbender
Version: 2.0.0
Excel Version: 365
Some more details as I have gotten farther.
In the Data Source Query of my TI process I have the following section that returns properly in the Preview
CASE WHEN upper(A.TOWN) like '%HALIFAX%NS%' or upper(A.TOWN) like '%BEDFORD%NS%' or upper(A.TOWN) like '%DARTMOUTH%NS%' then 'Y' ELSE 'N'END AS NS_METRO_FLAG
But when I try to add the same section to the vSQL on the Advanced - Prolog tab I get an error saying I need a semi colon.
'A.CREDIT_TIME_CODE AS NET_DAYS, ' |
'A.CREDIT_LINE, ' |
'A.NUM_BUDGET_PAYMENTS, ' |
'CASE WHEN upper(A.TOWN) like '*HALIFAX*NS*' % upper(A.TOWN) like '*BEDFORD*NS*' % upper(A.TOWN) like '*DARTMOUTH*NS*' then 'Y' ELSE 'N' END AS NS_METRO_FLAG ' |
I also tried it exactly the way it is on the Data Source but I figured I had to change it because % means or in a TI process
MarenC
Excel Version: Excel 2016
Post by MarenC »
% does not mean or when it is between single quotes. So I don't believe that is your problem.
Given you have single quotes in your case statement, you will need to escape them, best to use char(39) instead of a quote I think.
And of course, all statements need to end with a semi colon, so I would expect vSQL to end with a semi colon.
Maren
