Hi TM1 Community,
exporting a websheet to pdf can be formatted by defining the print area in Excel during creating the sheet.
But what about cube views? Is there a possibility to format the pdf export of cube views? Like freezing panes, at least. Without that, the exports are nearly useless.
I'll be grateful for any respond/idea/hint.
Configure pdf export of a View (TM1-Web / PA Spreadsheet Services)
- Version: 2.0.9
Re: Configure pdf export of a View (TM1-Web / PA Spreadsheet Services)
You could embed the cubeview within a book in Planning Analytics Workspace, set the size of the cubeview to 100% width, then use share to export it to PDF
- Version: 2.0.8
- Excel Version: MS 365
Hi burnstripe,
thanks for your idea.
Unfortunately my client does not have PAW, yet. Is there also a way to solve this issue in TM1-Web or PASS?
