Error in Opening Cube
Usman Abbasi
OLAP Product: IBM Cognose Tm1
Version: Version 9.4
Excel Version: 2019
Post by Usman Abbasi »
Hi, I am new to TM1. I loaded a data in cube but when i try to open it, it shows error that
(Objectlistisempty) Customer : View title subset is empty
kindly Help
Re: Error in Opening Cube
Usman Abbasi wrote: ↑Fri Oct 01, 2021 4:12 am Hi, I am new to TM1. I loaded a data in cube but when i try to open it, it shows error that
kindly Help
It sounds like you have a stuffed Default view; it was probably made up of one or more subsets that have since had their elements deleted, in particular in the Customer dimension. (Or it may be a dynamic subset which is returning no elements; either way the result would be the same.)
If you have a private "Default" view, delete it.
If you don't have a private "Default" view but have a public one, delete that instead.
