Transfer data
Houps
OLAP Product: Cognos Analytics
Excel Version: 2017
Transfer data
Post by Houps »
Hello, i need to transfer data in measure from 02->03->04 cubes.
Could someone help me with rule?
Form{Flat are in Measure{ST{CopyDataDetail.
I try do
IF ( !Form{Flat @= DB('ST{02.02.CopyDataDetail',!Orgstructure,!Scenario,!Version,!Rows,'4') );
['Measure{ST{CopyDataDetail':'4']=S:DB('ST{02.02.CopyDataDetail',!Orgstructure,!Scenario,!Version,!Rows,'4');
ENDIF;
but it doesn't work
Adam
OLAP Product: IBM PA
Version: 2.0.9.x
Re: Transfer data
Post by Adam »
Hi Houps,
I saw you registered earlier today, welcome to TM1 Forum!
I’m going to use the code-tag to make your script and mine easier to read.
If I understand right, you're trying to write the following rule:
ENDIF;
Appreciate what you're trying to do; You inadvertently created a hybrid of a rule and a turbo integrator script. This is evident by mixing of ['area statements'] - a hallmark of rules, and ENDIF; which is part of turbo integrator. TM1 doesn't quite work this way.
  • Rules are applied to cubes.
  • Turbo Integrator scripts are applied to processes.
  • You cannot mix the two.
Try this rule in cube ST{02.03.CopyDataDetail -- newlines and tabs are added for readability.
['Measure{ST{CopyDataDetail':'4'] = S: IF(
	!Form{Flat @= DB('ST{02.02.CopyDataDetail',!Orgstructure,!Scenario,!Version,!Rows,'4'),
		STET);
The if statement works just like an Excel IF(cond,true,false) statement.
Don't forget, you'll need a feeder in cube ST{02.02.CopyDataDetail:
SKIPCHECK;
# ... rules go here ...
FEEDERS;
# ... other feeders go here ...
# You need to substitute a value for XXXXX and YYYYY immediately below. You need to tell TM1 which Year{Month and Form{Flat to feed.
['Measure{ST{CopyDataDetail':'4'] => DB('ST{02.03.CopyDataDetail', !Orgstructure, !Scenario, !Version, 'XXXXX', 'YYYYY', !Rows, '4');
Also, in case you'd like more general pointers on TM1 rules, I posted on this not too long ago.
Let us know how you make out.
Take care,
Adam
Houps
Excel Version: 2017
Re: Transfer data
Post by Houps »
Big thank. It's help.
My code is:
	!Form{Flat @= DIMNM('Form{Flat',  DIMIX('Form{Flat', DB('ST{02.02.CopyDataDetail',!Orgstructure,!Scenario,!Version,!Rows,'4'))),
		STET
And feeders:
['Measure{ST{CopyDataDetail':'5'] => DB('ST{02.03.CopyDataDetailRow', !Orgstructure, !Scenario, !Version, DB('ST{02.02.CopyDataDetail',!Orgstructure,!Scenario,!Version,!Rows,'3'), DB('ST{02.02.CopyDataDetail',!Orgstructure,!Scenario,!Version,!Rows,'4'), !Rows, '5');
it's work
But a have a question. How i can load data from 02.03 to 02.04? "Rows" dimension make me :cry:
Re: Transfer data
Assuming we are talking about numeric data then you would need to have a consolidation of all elements in the rows dimension and then rule or TI the data at that level.
Houps
Excel Version: 2017
Re: Transfer data
Post by Houps »
I can add consolidate element in the Rows dimension.
Something like this.
How it can help me?
Re: Transfer data
When you reference 02.03 from 02.04 you need to replace !Rows with '0'.
Maybe I am missing something...
