I was wondering if someone can help me with the PAW Forecast feature.
I was trying to create my first forecast model following the example at: https://www.youtube.com/watch?v=c8fAftMecw4
However, every time I tried to create a forecast preview I get the same error (see attached screenshot) "Attemp to update a non-updatable cell"
PAW Forecast Feature - Ver. 2.0.62
mlorini
- Version: 2.8
- Excel Version: 365
- PAW_Forecat.JPG (27.1 KiB) Viewed 7134 times
Re: PAW Forecast Feature - Ver. 2.0.62
It likely means that it worked out a forecast and then tried to place it in cells which are either derived by rules (so it can’t put a value there) or protected by security (also can’t put a value there.)
Can you check the intersection you are running it for and see if you have access? If there are c-level cells it will try and write to the underlying n-level elements. And if the starting value is zero it will default to trying to do an equal spread to ALL underlying leaf cells.
- macsir
- Version: PAL 2.0.9
Try to forecast some simple detailed cells first to see if it works.
mlorini
- Version: 2.8
Well, I find the solution to my issue:ProportionSpreadToZeroCells was set to F in the tm1s.cfg file
# https://www.ibm.com/support/pages/syste ... s-be-false
ProportionSpreadToZeroCells=T
now I have the following issue:
- paw-timeout.JPG (20.58 KiB) Viewed 7092 times
