UseSSL
UseSSL
I was looking at a connection with the TM1 REST API to a customer's model. In the config file, we have UseSSL = T. When the TM1 server starts, it logs SSL Mode: 0. Does 0 mean True ? I haven't looked at it in any great detail but I found it weird.
jim wood
Version: PA 2.0.7
Re: UseSSL
Post by jim wood »
We have recently enabled SSL and the rest api code we've been using for a while no longer works, so there's some weird stuff happening and we are still looking at it.
Re: UseSSL
Hi Wim,
Seems fine on my side - What version are you trying on?
TM1 Build Number: 11.8.00500.12 (possibly PA 2.0.9.6)
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Logging Directory: c:\tm1 logs\XYZ
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Configuration Directory: c:\tm1 data\XYZ
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Raw Store Directory: c:\tm1 data\XYZ
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Port: 27472
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   HTTPPort: 27474
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Client Message Port: 27473
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Client Message Port does not accept Tm1Top connections.
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   IP Version: ipv4
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   SSL Mode: 1
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Key File: C:\Program Files\ibm\cognos\tm1_64\bin64\ssl\ibmtm1.kdb
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Key Stash File: C:\Program Files\ibm\cognos\tm1_64\bin64\ssl\ibmtm1.sth
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   FIPS Operation Mode: 2
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   NIST SP800 131A Mode: 1
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Certificate Authority: ibmtm1.arm
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Client Export Server Certificate: 0
33244   []   INFO   2021-05-18 15:53:13.521   TM1.Server   Security Mode: 1
Assuming you have double-checked that there is not another UseSSL statement in the file.
BR, George.
Re: UseSSL
Hello Jim, George,
Thanks for the replies.
It's server version 11.8.00100.13 which equates to 2.0.9.2 (July 2020).
There's only 1 line with UseSSL in the cfg file.
Emixam
Re: UseSSL
Post by Emixam »
Hello Wim,
It may sounds stupid but in the screenshot it shows log from 2020-09-29. Maybe they changed the UseSSL parameter recently ?
Re: UseSSL
Emixam wrote: Tue May 18, 2021 8:38 pm Hello Wim,
That doesn't sound stupid at all ! You were right, thanks !
ardi
OLAP Product: tm1, cognos bi
Re: UseSSL
Post by ardi »
jim wood wrote: Tue May 18, 2021 2:12 pm We have recently enabled SSL and the rest api code we've been using for a while no longer works, so there's some weird stuff happening and we are still looking at it.
I am also having the same issue. Were you able to figure out how to resolve this?
Ardian Alikaj
