9.1 API - ASP.NET / VB.NET
- kielmc
- Version: 10.2.2 FP4
- Excel Version: 2013
Does anyone have an example of using ASP.NET / VB.NET to connect to TM1 9.1?
AnthonyT
- OLAP Product: TM1, EV
- Version: 9.0 9.1 9.4 9.5 10.1 10.2
- Excel Version: 2003 2007 2010 2015
Re: 9.1 API - ASP.NET / VB.NET
Only via EV if that helps at all
Anthony
That's no moon - that's a space station
- kielmc
we've got EV, so i'd love to see your example!
AnthonyT
Here is what I do
Using the code behind page, I create the EV object as a new Literal Control, setting a few variables along the way
Then, using the aspx page I use a place holder to contain the new control
You can use the MyLoad procedure to set a few variables as well
I also use it to start off a few procedures that populate drop-down boxes with the contents of TM1 subsets, and initialize a few things
Hope this helps
Anthony
Partial Class ClientCostReport
Inherits System.Web.UI.Page
Dim ControlPlaceHolder As PlaceHolder
Dim litObjectTag As LiteralControl
Dim arrObjectTag() As Byte
Dim evServer As EV_Web_Service_DEV64.ExecutiveViewer
Dim SessionHeader As EV_Web_Service_DEV64.SessionHeader
Dim ReportPath As String = "/Cost Report/Client Cost Report"
Protected Sub Page_Load(ByVal sender As Object, ByVal e As System.EventArgs) Handles Me.Load
evServer = New EV_Web_Service_DEV64.ExecutiveViewer
evServer.Url = "http://Dev_Server/EVServer/WebService.asmx"
evServer.Credentials = System.Net.CredentialCache.DefaultCredentials
ControlPlaceHolder = Me.FindControl("PlaceHolder1")
ControlPlaceHolder.Controls.Clear()
SessionHeader = evServer.CreateSessionImpersonated("Windows", "", "", "", "")
Session("sessionID") = SessionHeader.ID
If Session("sessionID") <> "" Then
Dim nvc(7) As EV_Web_Service_DEV64.NameValue
nvc(0) = New EV_Web_Service_DEV64.NameValue
nvc(0).Name = "ControlID"
nvc(0).Value = "EVObject"
nvc(1) = New EV_Web_Service_DEV64.NameValue
nvc(1).Name = "SessionID"
nvc(1).Value = Session("sessionID")
nvc(2) = New EV_Web_Service_DEV64.NameValue
nvc(2).Name = "ToolBar"
nvc(2).Value = True
nvc(3) = New EV_Web_Service_DEV64.NameValue
nvc(3).Name = "TabBar"
nvc(3).Value = True
nvc(4) = New EV_Web_Service_DEV64.NameValue
nvc(4).Name = "Theme"
nvc(4).Value = "Ocean"
nvc(5) = New EV_Web_Service_DEV64.NameValue
nvc(5).Name = "Width"
nvc(5).Value = "85%"
nvc(6) = New EV_Web_Service_DEV64.NameValue
nvc(6).Name = "Height"
nvc(6).Value = "93%"
nvc(7) = New EV_Web_Service_DEV64.NameValue
nvc(7).Name = "Protocol"
nvc(7).Value = "HTTP"
arrObjectTag = evServer.Render(ReportPath, EV_Web_Service_DEV64.RenderType.ActiveX, nvc)
litObjectTag = New LiteralControl
litObjectTag.Text = System.Text.Encoding.UTF8.GetString(arrObjectTag).Replace("src=", "src=""http://Dev_Server/EVServer/CreateControl.js""")
ControlPlaceHolder.Controls.Add(litObjectTag)
End If
End Sub
End Class
<body onload = "MyLoad" >
<asp:Table Width="100%" >
<asp:TableRow id="T2r1">
<asp:TableCell id="T2r1c1" Width="85%">
<asp:PlaceHolder ID="PlaceHolder1" runat="server">Control Not Loaded</asp:PlaceHolder>
</asp:TableCell>
</asp:TableRow>
</asp:Table>
</body>
Sub MyLoad()
EVObject.EnableColumnHeaders = True
EVObject.EnableToolBar = False
EVObject.EnableTabBar = False
EVObject.EnableOffspreadBar = False
EVObject.AllowSaveView = False
EVObject.AllowDataEntry = False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationChangeDimensionLayout, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationChangeOffspreadSelection, True
EVObject.Allow ActionAuthorisationType.ActionAuthorisationChangeInspreadSelection, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationFormat, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationOptions, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationLayout, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationDynaSelect, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationCalculations, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationMemberDisplayNames, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationPrinting, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationActions, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationUndo, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationChangeNotes, False
EVObject.Allow ActionAuthorisationType.ActionAuthorisationConnection, False
' # COLOUR THE BACKGROUNDS #
EVObject.ActiveView.SetBackgroundColor BackgroundAreaType.BackgroundAreaTable, "White"
EVObject.ActiveView.SetBackgroundColor BackgroundAreaType.BackgroundAreaRowHeaders, "White"
EVObject.ActiveView.SetBackgroundColor BackgroundAreaType.BackgroundAreaColumnHeaders, "AliceBlue"
End Sub
Hope this helps
Anthony
Anthony
