What is the full custom number format for making zero values display the symbol "-" in TM1?
thks!
Custom Number Format to Make Zeros display -?
kiss351523
- Version: 9.5
Re: Custom Number Format to Make Zeros display -?
The number formats apply a similar logic to excel number formatting where it is split into 3 sections:
1/ Positive Numbers
2/ Negative Numbers
3/ Zeroes
Apply number formats to a dimension element ends up with slightly different connotation in Architect vs Workspace but the part you care about si the same:
In that example it uses a comma for thousand separator, encloses negatives in brackets and does not show decimals. The bit you care about is after the last semi-colon ( ; ) and it is just a hyphen/dash in order to show a dash.
1/ Positive Numbers
2/ Negative Numbers
3/ Zeroes
#,##0;(#,##0);-Declan Rodger
Strictly speaking it doesn't enforce using comma as the thousand separator. Whatever the local regional settings are on the user's desktop for thousand separator will be substituted.
semaxan
- Version: 2.0
I was helped to get the following format in Architect without showing any decimals but with thousand separation using spaces.
- TM1 Architect number format
- TM1format.PNG (3.68 KiB) Viewed 3399 times
semaxan
- Version: 2.0
Actually, instead of using a short hyphen - I preferred the longer en-dash (ALT+0150). You could also use the even longer em-dash ALT+0151. But the middle one is the one I use.
