If hierarchy creation is enabled should I always use Hierarchy functions instead of dimension functions?
So HierarchyElementInsert instead of DimensionElementInsert, HierarchyElementComponentAdd instead of DimensionElementComponentAdd etc?
Maren
Hierarchy Functions
ascheevel
- Version: PA 2.0.9.1
- Excel Version: 365
Re: Hierarchy Functions
For modifying the base hierarchy of the dim, you can continue to use the original functions. For modifying the alternate hierarchies, you'll absolutely need to use the hierarchy functions.
MarenC
- Excel Version: Excel 2016
thanks ascheevel.
So if hierarchy creation is enabled then it is probably better to use the hierarchy functions even for the default/base hierarchy, I guess my question was if hierarchy creation is enabled does this make the dimension functions moribund?
Maren
Maren
True. Even if hierarchy creation is disabled they can still be used.
