Hi Guys
Silly Question - how do you set subset to expand above when you click on it?
Many thanks!!
Chris
Pax - Expand Above
- Steve Rowe
Re: Pax - Expand Above
In the set editor toggle the Show Totals Leading / Trailing which is the Epsilon with the bars above and below it in the middle of the editor.
Make sure the set editor is in to Hierarchy mode rather than definition mode as well as this (might) make a difference too.
- Version: 10.3.0
Hello
I've looked at this thread as well.
https://www.tm1forum.com/viewtopic.php?t=14451
The TM1ToggleExpandMode seems to stop the dynamic formatting working in a Dynamic PAfE report, making all roll ups be Level 0?
In this case, at the bottom,
5 Total Interest... is actually a Level 1
5100 Interest... is actually a Level 2
Also, you can still click on the + signs, and they then expand below??
Am I missing something?
- gtonkin
TM1RptRow has a parameter to expand above. Try set it and see if that helps. Remove the expand mode from the MDX string too.
- Version: 10.3.0
Ah, I didn't know about that parameter.
Thanks George
Thanks George
