CSV file as data source, why TI is reading one more column?
lynnsong986
Post by lynnsong986 »
I have a CSV file with 12 columns as data source, but the preview shows V1.......all the way up till v13 (all blanks underneath it - v13 is non existing in the CSV, column 13 has absolutely nothing), also there are 13 variables in the Variable tab. How can I get rid of this v13?
thanks so much!
ascheevel
Version: PA 2.0.9.1
Excel Version: 365
Re: CSV file as data source, why TI is reading one more column?
Post by ascheevel »
What harm is variable V13 causing you? You can simply ignore it.
lynnsong986
it's not causing anything really, I just don't understand why it showed up...but I guess I can definitely ignore it :) sounds like this does happen in TM1... thanks!
Because number of fields = number of separators + 1
If the last field has a trailing separator then this marks the start of a new field.
Indeed, make sure there are not additional separators.
If an Excel file is the basis for the csv, then make sure that the last cell in Excel (Ctrl-End) matches the last cell of your data.
If not, remove all columns (and rows) that are excessive, save the file (important!) and then save as csv again.
lynnsong986
Wow that must be it!! thanks so much for your time letting me know!
