We are on TM1 9.4, using Excel 97 and VBA.
Here is my code:
Sub ElementList()
'Description:
' This procedure retrieves Dimension Elements and Name Attribute
'Parameters:
' None
'Return:
' None
Const FIXED_STR_LENGTH = 30
Dim hUser As Long, hServer As Long
Dim sDimensionName As String, sAttribute As String
Dim voDim As Long
Dim voDim1 As Long
Dim voTemp As Long
Dim voTemp1 As Long
Dim voTemp2 As Long
Dim voTemp3 As Long
Dim voTemp4 As Long
Dim voEle As Long
Dim hPool As Long
Dim ibOK As Integer
Dim viEleCount As Long
Dim iEleCount As Integer
Dim iCubeCount As Integer
Dim pEleHandles As Long
Dim iEle As Integer
Dim pEleNames As Long
Dim pEleAttr As Long
Dim sEleName As String * FIXED_STR_LENGTH
Dim iTemp As Integer
Dim sAttributeName As String * FIXED_STR_LENGTH
hUser = TM1_API2HAN
hServer = TM1SystemServerHandle(hUser, "ph_bpm_test")
sDimensionName = "PayEmployee"
sAttribute = "Name"
' Create General Pool
hPool = TM1ValPoolCreate(hUser)
' Locate Dimension
voDim = TM1ObjectListHandleByNameGet(hPool, hServer, TM1ServerDimensions(), TM1ValString(hPool, sDimensionName, 0))
' Determine the number of elements in the dimension
viEleCount = TM1ObjectListCountGet(hPool, voDim, TM1DimensionElements())
iEleCount = TM1ValIndexGet(hUser, viEleCount)
' Create a pool for the element handles
pEleHandles = TM1ValPoolCreate(hUser)
' Retrieve each element handle in succession, store in value pool
For iEle = 1 To iEleCount
voTemp = TM1ObjectListHandleByIndexGet(pEleHandles, voDim, TM1DimensionElements(), TM1ValIndex(hPool, iEle))
Next iEle
' Create pools for element name and attribute
pEleNames = TM1ValPoolCreate(hUser)
pEleAttr = TM1ValPoolCreate(hUser)
' Look at each element, if there are no read rights skip
' otherwise retrieve name and attribute
For iEle = 0 To iEleCount - 1
voEle = TM1ValPoolGet(pEleHandles, iEle)
If TM1ValObjectCanRead(hUser, voEle) <> 0 Then
voTemp2 = TM1ObjectPropertyGet(pEleNames, voEle, TM1ObjectName())
voTemp1 = TM1ObjectAttributeValueGet(pEleAttr, voEle, TM1ValString(hPool, sAttribute, 0))
End If
Next iEle
' Output Dimension Elements and Names
iTemp = TM1ValPoolCount(pEleNames)
For iEle = 0 To iTemp - 1
voTemp3 = TM1ValPoolGet(pEleNames, iEle)
TM1ValStringGet_VB hUser, voTemp3, sEleName, FIXED_STR_LENGTH
voTemp4 = TM1ValPoolGet(pEleAttr, iEle)
'Code lockes up at this line right here.********************************************************
TM1ValStringGet_VB hUser, voTemp4, sAttributeName, FIXED_STR_LENGTH
Debug.Print "Element: " & sEleName & " Name: " & sAttributeName
sEleName = ""
Next iEle
' Destroy all pools
TM1ValPoolDestroy (hPool)
TM1ValPoolDestroy (pEleHandles)
TM1ValPoolDestroy (pEleNames)
TM1ValPoolDestroy (pEleAttr)
Exit Sub
DONE:
' Destroy all pools
End Sub
Thanks for your help everyone!
