How to create dynamic view with the help of MDX?
habibullah.sayyed
Version: v10.x
Excel Version: excel 2016
Post by habibullah.sayyed »
Hello Everyone,
I want to make a Dynamic view through MDX, please explain step by step cause I am not expert in this... :)
orlando
Version: PAL 2.0.8
Re: How to create dynamic view with the help of MDX?
Post by orlando »
what did you tried until now to make a dynamic view?
Where will you use this view later?
Where does the parameter come from, to make it dynamic?
Best regards
orlando
habibullah.sayyed
Version: v10.x
orlando wrote: Thu Aug 29, 2019 7:16 am Hi,
Best regards
orlando
I did not tried yet but I know from where to get MDX code(get from Expression Window).
I will be using this on the views which are getting corrupted.
And the parameter is coming within the cube.
Best Regards,
Habib
orlando
Version: PAL 2.0.8
Post by orlando »
don't have the time for an example code - but here are some links and hints
Best regards
orlando
habibullah.sayyed wrote: Thu Aug 29, 2019 9:44 am
You mean the MDX Expression Window of a subset?
Be aware that the MDX produced there might not work in Turbointegrator
habibullah.sayyed wrote: Thu Aug 29, 2019 9:44 am I will be using this on the views which are getting corrupted.
you should read:
https://www.ibm.com/support/knowledgece ... ons_N728E8
and:
https://www.ibm.com/support/knowledgece ... ons_N72463
and:
https://www.ibm.com/support/knowledgece ... ons_N7121E
keep an eye on
ViewCreate
SubsetCreateByMDX
ViewSubsetAssign
CellGetN
CellGetS
Emixam
Post by Emixam »
If you want to create a dynamic view and use it as a source in a TI you should do something like this:
# Other Subset : Static
# Account : MDX
sDimAccount = 'GL Account';
sTopAccount = CellGetS( sLookUpCube, ..., ..., ...);
SubsetCreatebyMDX( sSubName, '{TM1FILTERBYLEVEL( {TM1DRILLDOWNMEMBER( {['  | sDimAccount | '].[' | sTopAccount | ' ]}, ALL, RECURSIVE )}, 0)}' );
ViewSubsetAssign( sSourceCube, sViewName, sDimAccount, sSubName );
# Setup Source Data - VIEW
DATASOURCENAMEFORSERVER = sSourceCube;
DATASOURCETYPE ='View';
DATASOURCECUBEVIEW = sViewName;
# View Extract
ViewExtractSkipRuleValuesSet( sSourceCube, sViewName, 1 );
ViewExtractSkipCalcsSet( sSourceCube, sViewName, 1 );
ViewExtractSkipZeroesSet( sSourceCube, sViewName, 1);
We are using a MDX expression to retrieve all Level 0 elements under a consolidated element store in a sLookUpCube.
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
I am sure someone will say it would then be a good idea to make the subset(s) static.
But I haven't yet seen where that makes anything run quicker!
No sure how most people create views in TM1 but I just have one create view process which uses the expand and tabdim functions
and creates a view for any given cube based on mdx for each dimension.
regards, Mark
Extirpator
Version: Planning Analytics 2.0.7
Excel Version: Excel 2016 64-bit
Post by Extirpator »
It might help to understand if you're working with TI process, a Planning Analytics Workspace (PAW) view, a dynamic report in Planning Analytics for Excel (PAX), or somewhere else.
For better or for worse, I have created quite a few dynamic views in PAW and PAX over the past week and can probably help.
