PowerShell issue
PowerShell issue
Hello all,
I'm trying to achieve the following. In several load processes I have a line of AsciiOutput in case an error occurs.
In the TM1 logging directory I get files with a certain filename pattern, involving the name of the offending process and a timestamp. The file itself contains 1 line, a description of the error.
Now, when all loads are finished, I want to have a chore that sends an email containing all files and their contents - as a summary for the TM1 administrator to look at, process by process.
I wrote a PowerShell script as follows. When I use TI to create a text file containing the script (Prolog tab) and I execute it with ExecuteCommand and the -File option (Epilog tab), it works perfectly. A csv file contains all "filename: error description" combinations.
vPS = 'Get-ChildItem "D:\Logs\a.txt" | ';
vPS = vPS | 'foreach-object { $fname=[System.IO.Path]::GetFileNameWithoutExtension($_); ';
vPS = vPS | 'get-content $_ | foreach-object { echo $fname": "$_ >> "D:\Logs\output.csv"}}';
DataSourceAsciiQuoteCharacter = '';
AsciiOutput( 'D:\Logs\test.ps1', vPS );
ExecuteCommand( 'powershell.exe -ExecutionPolicy ByPass -file "D:\Logs\test.ps1"', 0 );
However, when I use the same PowerShell script in TI, and I execute it with ExecuteCommand and the -Command option, it does not work. A csv file is not created:
ExecuteCommand( 'powershell.exe -Executionpolicy ByPass -command ' | vPS, 0 );
Now, if I take out the variable $fname in the output (last line), I get a file. So it seems related to that variable. But here I am stuck !
I am aware that a DOS command can also work, but I am just eager to know what is at stake here.
What is the difference between TI running from a ps1 file (that it creates first by himself), and passing a command ?
Note; in the PS script above I use only 1 file (a.txt) as the source but in reality I loop over the files obeying a filename pattern, files only produced today, etc.
Thanks a lot !
Wim
Re: PowerShell issue
Allright, I got it. Again, double quotes, single quotes, spaces, backticks misery...
Here is the full code you need in TI. Individual text files are called: 'ERROR - nameoftheprocess_20190716 012345.txt' (for today)
cLog_Folder = GetProcessErrorFileDirectory;
cAll_Errors = 'output.csv';
cFullname = cLog_Folder | cAll_Errors;
vPS = 'Get-ChildItem "' | cLog_Folder | 'ERROR` -` *_????????` ??????_?????.txt" | Where-Object {$_.LastWriteTime -gt (Get-Date).AddDays(-1)} | foreach-object { $fname=[System.IO.Path]::GetFileNameWithoutExtension($_); $fname_short=$fname.substring(8, $fname.Length - 14); get-content $_ | foreach-object { echo $fname_short'': ''$_`n >> "' | cFullname | '"}}';
ExecuteCommand( 'powershell.exe -command ' | vPS, 0 );
The output.csv file then contains x lines, with this structure for each line: 'name of the process: error description'
Last step will be to send an email with the output.csv file as contents. Or, have PowerShell send the email and skip the intermediate output.csv file alltogether :-)
If someone can simplify all this, please do so.
# alternatively, with a temporary file, but that's not so neat:
AsciiDelete( cFullname );
AsciiOutput( GetProcessErrorFileDirectory | 'temp.ps1', vPS );
# if needed, bring the next line of code to the Advanced > Epilog tab
ExecuteCommand( 'powershell.exe -file "' | GetProcessErrorFileDirectory | 'temp.ps1"', 0 );
Drg
OLAP Product: tm1
Version: 10.2.0 - 10.3.0
Post by Drg »
Hi all i use next construction tu run powershell comands.
powershell -command "& { <write your script here> }
PSscript='powershell -command "& {set-content -path '|Filepath|' -value '|exportstring|' }"';
EXECUTECOMMAND( PSscript , 1 );
this saves us situations when the script needs to be given permission, but it also brings a little pain with quotes and double quotes
Drg wrote: Tue Jul 16, 2019 6:50 ambut it also brings a little pain with quotes and double quotes
Indeed, don't you close the double quotes in the code ?
Drg
OLAP Product: tm1
Post by Drg »
Wim Gielis wrote: Tue Jul 16, 2019 1:53 pm
Oh Yes, I hurried with the answer so I missed them [corrected] But I thought the essence of the question is that you don’t know how to execute the scripts.
However, I was talking about the situation with quotes when you need to use double and single quotes inside a block of something like this (yes, these are simply dumb examples of wrapping different quotes that are revealed at the Turbointegrator level then at the cmd level and after at the powershell level)
vFlagSet='powershell -command "& {';
vFlagSet=vFlagSet | '$SomePSvariable=get-content -path ''c:\temp\bla.txt'' ';
vFlagSet=vFlagSet | 'sc -path '''|vAvailableProdInstanceFlagPath|''' -Value \"$SomePSvariable\" -Force -ErrorAction SilentlyContinue;';
vFlagSet=vFlagSet |'(Invoke-RestMethod -Uri \"http://'| AdminHost |':5895/api/v1/Servers(''' | Server | ''')\").AcceptingClients;'
vFlagSet=vFlagSet |'$HttpPort=8001;Invoke-RestMethod -Uri \"http://'| AdminHost |':$HttpPort/api/v1/Cubes?$filter=Name eq'''| CubeName |'''&$count=true'\"; }"';
By now it works, but I will play around with your examples.
