Do we have any option to connect SAP Data Services to TM1 system. Please advise.
Integrate TM1 with SAP Data Services(BODS)
Re: Integrate TM1 with SAP Data Services(BODS)
Arb1486,
I have never used BODS, but there are a few options for TM1 for getting at the data:
*discaimer: I work for the company who makes TM1Connect.
- If BODS supports OLEDB for OLAP you can connect directly to TM1 and access the data as a multidimensional datasource.
- If BODS supports ODBC, you can use a third party connector, such as TM1Connect (www.tm1connect.com) that makes TM1 views appear as relational datasets.
- Flat files can be exported out of TM1 and then loaded into BODS. Not ideal for interactive or real-time data, but an option.
- It is potentially possible to connect to the REST API as well, but the problem is that the consuming application (BODS) would have to be pretty intelligent to be able to assemble and work with the REST API. A single pull of data could potentially require multiple calls and data passed between the calls. It is not (in all cases), just a simple GetData request.
- Steve Rowe
To the OP, it would be worth being explicit about the direction you want the data to flow, the answer will be different.
