Hello Everyone,
I have a problem in TM1 PAx plugin, its was working fine, and suddenly crashed. Then IBM Planning Analytics Menu in excel was disappeared. I have tried adding it in excel addin, then close the excel and reopen. Again IBM Planning Analytics menu was not there.
Any suggestions, welcome. Thanks.
Tm1 PAX plugin disappears
kavitha2002
- OLAP Product: tm1
- Version: 10.3.10100.8
- Excel Version: 14
Paul Segal
- Version: TM1 11 and up
ascheevel
- Version: PA 2.0.9.1
- Excel Version: 365
Re: Tm1 PAX plugin disappears
Second the comment making sure the com add-in is enabled. Sometimes after the add-in gets disabled and we've subsequently re-enabled it, it still doesn't load on excel startup forcing the user to re-enable it each time. When that happens we modify the load behavior of the add-in in the registry to get it loading on excel start again.
kavitha2002
- OLAP Product: tm1
- Excel Version: 14
Thanks.. I have changed the registry behaviour to 3 in regedit then it works perfectly
