Hello there, I have a question.
My problem: I have made a solution based on cognos TM1 and user interface using Planning analytics, then I made a process to rebuild cube view based on some selections in other cube.
The data refreshed and the cube created but 'The filters keep the old value, So you need to click on all filters and select the element you need based on your selection early'.
Hint: although My process set the element I want to filter int the cube filter but the workspace doen't feel. Still you need to refresh the filters.
On Architect the view was created by ti and did what I want.
Refresh means click on the filter and select your element.
Thanks in advance.
Best Regards.
Refreshing of planning Analytics Workspace filters.
Hector2005
- OLAP Product: MOLAP
- Version: 10.2
- Excel Version: 2013
Edward Stuart
- Version: All
- Excel Version: All
Re: Refreshing of planning Analytics Workspace filters.
Can you rephrase the question(s) as it is not very clear what you are asking?
I assume you mean your Planning Analytics Workspace filter(s) are not updating where your Planning Analytics cube(s) filter(s) are updating?
