Problem getting PAW to run properly
Hazue
Version: 2.0.3
Post by Hazue »
Hi guys,
I am currently having some issues getting PAW to run properly after installation on my Windows 2016 server machine. I have followed the youtube tutorials uploaded by IBM Business Analytics Support and have come to a point where everything seemed to have been installed accordingly.
I have also reconfigured the default port for PAW to port 82 as it initially clashed with IIS. However, whenever I try to access the IP address of the server at port 82, I would get the "The site can't be reached, refused to connect" page error and can not seem to get the PAW login page to appear.
For the record, whenever I access the server IP address at port 80, the IIS homepage does appear.
Could someone please point me in the right direction, would really appreciate it, thanks!
dr.nybble
Excel Version: Excel 2007
Re: Problem getting PAW to run properly
Post by dr.nybble »
Try to run the scripts/launch.ps1 script to see if you can access PAW directly against the container IP address.
If so, ensure your firewall will permit inbound connections on port 82.
dr.nybble wrote: Wed Jul 04, 2018 12:44 pm Try to run the scripts/launch.ps1 script to see if you can access PAW directly against the container IP address.
"Error: No such object: pa-gateway"
But you do get a nice instance of Chrome out of it.
I am so sick of banging my head against Docker that I cannot even speak of it.
hyperbarem
Version: 2.0.3
Post by hyperbarem »
Hello.
I have a problem with the Authentication Service on IBM Planning Analytics Workspace installed on Windows 2016 Server inside a VMware.
Verifying a working virtualized Ubuntu Server in IBM Planning Analytics Workspace Administration Tool (PAWAT), there are a service that is not present in Windows Server called "Authentication"
Running PAWAT for validation, this result OK for the three elements.
But the service "Authentication" is not present in Windows Server...
So login screen never comes and stays in: "Planning Analytics Workspace is unnavailable. try again in a few minutes".
Please help, I just begun to have problems in my job on this.
Any help is appreciated.
