show recently added elements in subset.
escape18in
OLAP Product: IBM Cognos BI
Excel Version: Excel 2010
Post by escape18in »
Hi All ,
i have dimension which have elements lets say
1
2
3.
Now after load 2 more elements is added
1
2
3
4
5
Now in a worksheet i want to show only those recently added elements.how can i achieve this? i have tried with index sort like {Subset ( {TM1FILTERBYLEVEL( {TM1SORTBYINDEX( {TM1SUBSETALL( [Dimension] )}, DESC)}, 0)}, 1, 25)} but it is not working as TI assigning Index randomly. i have hierarchies in dimension as well.
tm123
OLAP Product: tm1, cognos bi
Re: show recently added elements in subset.
Post by tm123 »
Why don't you add an attribute to the dimension and use it for Filtering or SOrting? You cannot rely on the Element Index since it changes
escape18in
tm123 wrote: ↑Wed May 16, 2018 12:36 pm Why don't you add an attribute to the dimension and use it for Filtering or SOrting? You cannot rely on the Element Index since it changes
How attribute will identify the new element? it is not necessary in source data that new elements will come at last if i assign attribute as incremental numbers it will not work. i was assuming for any new element TM1 assign index in incremental order.
tm123
Post by tm123 »
escape18in wrote: ↑Wed May 16, 2018 12:44 pm
I don't understand your question maybe, but if you want to have an attribute that keeps the Element Inserting Order, you don't need to have this from data source but you can achieve this in the TI process. The simplest way is to use DIMSIZ but that will count consolidated elements also, and I am not sure if you want that. But there are more elegant ways of doing this, still in TI.
escape18in
tm123 wrote: ↑Wed May 16, 2018 12:50 pm
i will assign numbers in attribute from TI only.but how i identify that 2 elements have recently added which was not there previously. i have a requirement that i have a input cube with 100s of records. in those records some null as well. what user asked is he wants to see only those records which is recently added not all (including nulls) so that it is easier to him to put some values instead of searching in a cube.
What is your definition of "recently added elements"? Those added overnight from an automated process? Those added by a user since the last time the cube was checked? It's a lot more involved than your simple question. The best way to do this would be to add an attribute on this dimension, as already suggested, and use that attribute to filter via MDX. If it was me I would have an attribute called "Date Added" and populate it with the date and time (numeric, using NOW()) in the TI process when the element gets added. You can then have a cube view or reports that filter based on specific dates.
