Powershell to logoff and clean profile on another server
jimhung777
Post by jimhung777 »
Hey guys,
Here is the code I execute successfully.
#TI
sCommand = 'Powershell D:\TEST\file.ps1';
ExecuteCommand(sCommand, 0);
#PS
New-Item c:\TEST\new_file.txt -type file
However, when I tried to use TI to call PowerShell to log off a user or clean user's profile on another server, it did not work!
I'm sure this code can be executed by Powershell.exe merely.
#servername: XENPW55CV.woo.unatu
#username: 177684
#serverOA: 10.35.36.30
#clean user profile
(Get-WmiObject Win32_UserProfile -ComputerName XENPW55CV.woo.unatu -Filter "localpath='C:\\Users\\177684'").Delete()
#log off user
logoff ((quser /server:10.35.36.30 | Where-Object { $_ -match 177684 }) -split ' +')[2] /server:10.35.36.30
I don't know what's wrong... :o :o :o Is there anyone could help us or give us some direction?
Thanks so much! :)
PavoGa
Excel Version: 2013 PAW
Re: Powershell to logoff and clean profile on another server
Post by PavoGa »
Might try changing to this:
sCommand = 'Powershell D:\TEST\file.ps1 2>ErrorFile.txt';
and try to capture any errors the Powershell script is returning. The TI code looks fine.
Ty
Cleveland, TN
Can you run any PS script?
jimhung777
PavoGa wrote: Thu Apr 26, 2018 12:51 pm Might try changing to this:
Hi PavoGa,
Thank you for your idea!
Even though I can't run the code you provide, I still look for an alternative to reach the same result..
Here it is.
#PS
#log off user
set-content D:\TEST\error.log $error
Wim Gielis wrote: Thu Apr 26, 2018 1:15 pm Can you run any PS script?
Hi Wim, definitely.
I can run PowerShell with the code above, but when it comes to using TI to call .ps1, it failed to log off the user.
And I also put PS script in TI, still not work now.
Hopefully, with the help of PavoGa, I got some clue.
Error [5]:Access is denied.
Could not logoff session ID 1, Error code 5
macsir
Version: PAL 2.0.9
Post by macsir »
Check your service account you are using for TM1. It might be the service account don't have proper privilege compared with the one you run the PS script.
jimhung777
macsir wrote: Thu Apr 26, 2018 9:16 pm Check your service account you are using for TM1. It might be the service account don't have proper privilege compared with the one you run the PS script.
Hi macsir,
You are GOAT.
In DEV environment, it works according to your instruction.
But it still has some problem in PROD, I will upgrade from Powershell 2.0 to 4.0 to see if it is about the version. (now DEV 4.0, PROD 2.0)
Thanks!
