TM1 Scripting
venureddy
- OLAP Product: EXel
- Version: 10.2
- Excel Version: 15
TM1 Scripting
How can I modify text in generated section in Turbo Integrator.To write scripts
Re: TM1 Scripting
You can't.
If you don't want the code executed, either remove the mappings etc which generated the code, or wrap the code block as follows:
if(1=0);
# generated code
# end generated code
endif;
venureddy
- Version: 10.2
- Excel Version: 15
Re: TM1 Scripting
Then Where Dimension sorting order is done
Re: TM1 Scripting
Add a function in the Prolog. DimensionSortOrder
