As a rule of thumb with software higher release clients can communicate with a lower release server since they tend to superset the capabilities of an earlier release. Once they know what release they are talking to they can automatically dumb down for the lesser release.
This does not seem to be true for TM1 9.4 Client with 8.3.3 server. In architect the "TM1" appears but after a delay no list of servers appears underneath it.
I checked with
telnet server-name 5495
that the admin server was listening and that worked fine.
also telnet server-name 12345
checked for the TM1 server and that worked fine.
I am a posting this for information unless any one knows otherwise.
9.4 Client seems incompatible with 8.3.3 Server
John Hammond
- OLAP Product: PAW/PAX 2.0.72 Perspectives
- Version: TM1 Server 11.8.003
- Excel Version: 365 and 2016
- George Regateiro
- Version: 10.1.1
- Excel Version: 2007 SP3
Re: 9.4 Client seems incompatible with 8.3.3 Server
From the 9.4 Readme
Using a newer TM1 client with an older TM1 Admin Server and/or TM1 server is not a supported TM1 environment. If you use TM1 Perspectives/Architect 9.4 with older TM1 servers, you will experience unexpected behavior; the TM1 client may hang or not even open when started. If the TM1 client does open, older servers may be listed in the Server Explorer, but the following error displays when you try to log in: Log in Failed: SystemServerConnectionInvalid.
Sorry to disappoint you John, not the case for TM1 and never has been. The opposite is actually the case: older clients can communicate with newer server version but newer client can never talk to older server.John Hammond wrote:As a rule of thumb with software higher release clients can communicate with a lower release server since they tend to superset the capabilities of an earlier release.
You can play around with this a little with the ClientVersionMinimum and ClientVersionMaximum server config parameters.
And if you have a 9.1 or 9.4 server with a 9.0 or earlier client then also need to remember UseSSL=F otherwise older clients won't see the server.
But the golden rule is newer client will never see older server.
