When trying to insert an Excel report from a TM1 application, we get an error:
Error creating a TM1Web MDV instance: [object Object]
See attached screenshot.
Has anyone seen this before or might know a possible solution?
Thanks a lot!
Kris
PAW error when trying to insert a report from TM1 Applications
kschepens
- Version: 2.0
- error.jpg (99.98 KiB) Viewed 2857 times
- Steve Rowe
Re: PAW error when trying to insert a report from TM1 Applications
My first thought here is to check if TM1 Web is working correctly, if you can't see the report in TM1 Web you won't see it in PAW. The service IBM Cognos TM1 Application Server (ie. TM1 Web) must be running as well as PAW for Websheets to work (I think!)
I've not seen this message before.
