Hold consolidation via TI
hittony
Version: 10.2.2 FP6
Post by hittony »
We have a requirement that we need to populate a consolidation and make it uneditable, however users should have the write access on its child members. I think of Hold functionality in Perspectives or in CAFE, but is it possible to meet the requirement via TI on the back-end ? I'm not very familiar with Data Reservation, but can it be a solution ?
Thanks for your ideas
TM1 + CAFE 10.2.2 FP6
Elessar
OLAP Product: PA 2
Version: 2.0.9
Re: Hold consolidation via TI
Post by Elessar »
You can grant 'READ' access to consolidation in }ElementSecurity cube (or using Right click on dimension, Security). Also, you can use ElementSecurityPut TI function.
Do you need to maintain the values at the consolidated level because you are talking about a hold functionality ?
hittony
Version: 10.2.2 FP6
Post by hittony »
Wim Gielis wrote: ↑Tue Aug 29, 2017 3:29 pm Do you need to maintain the values at the consolidated level because you are talking about a hold functionality ?
Yes, they should not be changed by BU, while all leaf members can be changed.
hittony
Version: 10.2.2 FP6
Post by hittony »
Elessar wrote: ↑Tue Aug 29, 2017 3:14 pm Hello,
Thanks Elessar for your suggestion, it means that if I have a TI to populate the consolidation, the process have to change the access to "WRITE" first, then put the data, and in the end change the access back to "READ".
But what if I use rules to populate the consolidation ?
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
hittony,
I think I didn't understand you right. What do you mean by "populate the consolidation"? A screenshot would be useful
