Stuck on a if Condition.. too silly
LutherPaul
Post by LutherPaul »
Hi Gurus,
I am stumped on a simple if condition which fails miserably. I am reading data from a csv file.
The first condition to check for blank works and fails checking 'N/A', <>0 and ='N'.
Can someone tell me where I am going wrong?
the condition translates to
if Proj_code is not blank or proj_code is not equal to 'N/A' or Proj_code is not equal '0' or if NewBuss is equal to 'N'
if ( Proj_code @<> '' % Proj_code @<> 'N/A' % Proj_code @<> '0' % NewBuss @= 'N') ;
EndIf;
I have verified that the data is 'N/A', '0'. Dont understand why the OR condition fails. Can someone please help?
Paul.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: Stuck on a if Condition.. too silly
Post by Michel Zijlema »
LutherPaul wrote:the condition translates to
EndIf;
So you're saying the data is 'N/A', '0' and you're checking on is not equal to 'N/A' or is not equal to '0'.
Isn't that your issue? Otherwise you need to be a bit more clear on what you expect to happen inside and outside of the if statement.
Michel
LutherPaul
Thanks Michel for replying.
I have bad data coming in with values like 'N/A', '0', 'ASDF', which I want to avoid.
When the data is not in ('N/A', '0', 'ASDF'), I want my if to work else, nothing.
Hope I am clear.
Paul.
As Michel said, you need ANDs , not ORs i.e. not blank and not N/A and not 0 etc.
BR, George.
With code like this you are sort of applying a double negative... if the project code is "N/A" it can't also be blank so by using an or on it; the "N/A" gets through as it is not blank or 0.
Its sometimes easier to say if something is equal to such and such then itemskip.
True. In Metadata and Data tabs with more than a handful lines of code, I tend to use Itemskip and Itemreject first.
All other cases that remain will be treated with the remaining code.
Michel Zijlema
declanr wrote:Its sometimes easier to say if something is equal to such and such then itemskip.
I second that. To me it was not clear whether the If statement enclosed an ItemSkip or the actionable code...
I would reverse the conditions and put an ItemSkip inside the if and the actionable code after the endif.
Otherwise (the actionable code still within the if) the condition should I assume be:
if ( (Proj_code @<> ''  & Proj_code @<> 'N/A'  & Proj_code @<> '0') % NewBuss @= 'N') ;
Michel
LutherPaul
Thanks. That was stupid of me.
