I have 2 cubes with the following structure:
Cube 1:
Dimensions: Year, Month, BusinessLine, ProductType, Stage, Measures
Cube2:
Dimensions: Year, YearTo, Month, MonthTo, BusinessLine, ProductType, Stage, Measures
Rules in Cube 2:
SKIPCHECK;
['Measure']=N:DB('Cube 1',!Year,!Month,!BusinessLine,!ProductType,!Stage,'Measure');
FEEDERS;
Feeders from Cube 1 to Cube 2:
['Measure']=>DB('Cube2',!Year,'2015',!Month, '1',!BusinessLine,!ProductType,!Stage,'Measure');
['Measure']=>DB('Cube2',!Year,'2015',!Month, '2',!BusinessLine,!ProductType,!Stage,'Measure');
['Measure']=>DB('Cube2',!Year,'2015',!Month, '12',!BusinessLine,!ProductType,!Stage,'Measure');
['Measure']=>DB('Cube2',!Year,'2016',!Month, '1',!BusinessLine,!ProductType,!Stage,'Measure');
['Measure']=>DB('Cube2',!Year,'2016',!Month, '12',!BusinessLine,!ProductType,!Stage,'Measure');
I have tried to write the feeders from Cube 1 to Cube 2 as:
['Measure']=>DB('Cube2',!Year,{'2015', '2016'},!Month,{'1','2', '3', '4', '5', '6', '7', '8', '9', '10', '11', '12'},!BusinessLine,!ProductType,!Stage,'Measure');
but I received the error: "Sintax error on or before: "{'2015', '20 invalid string expression" "
I have also tried to put the dimension before, but was the same error:
['Measure']=>DB('Cube2',!Year,YearTo:{'2015', '2016'},!Month,{'1','2', '3', '4', '5', '6', '7', '8', '9', '10', '11', '12'},!BusinessLine,!ProductType,!Stage,'Measure');
Any solutions?
Feeders Problem ( Range )
AnonimusMax
- Excel Version: 2013
Re: Feeders Problem ( Range )
That's an easy one.
{ } is supported on the left hand side of the feeder or rule, but not on the right hand side.
Either duplicate it, either feed a consolidated element grouping those 12 elements.
AnonimusMax
Thank you for the fast reply.
I already did it with the consolidated element. But let s say i don t want to feed all the years that i have, and i only want 2015,2016. in the all element i have all the years.
So it s not possible to select only a range? or only 2-3 values like in the left side?
Thank you
Thank you
No.
Duplicate your feeder rule for 2 years.
Or create a consolidation with 2015 and 2016 and feed that consolidation. That is the best solution because probably next year you will update the years. Then you only change the children and reprocess the feeders.
AnonimusMax
ok,
Thank you for fast reply
i will do that
Yes but there is another "hardcoded array notation" for feeders which is supported on the right hand side of a rule. You can just separate the items you want to feed with a comma.Wim Gielis wrote:{ } is supported on the left hand side of the feeder or rule, but not on the right hand side.
e.g.
[A] => , [C], [D];
or
[A] => , DB(), DB(), ...
But I agree that rather than hardcoding it would be better to create a "technical consolidation" in the Year dimension e.g. "Years to Feed" with children 2015 & 2016. The consolidation can then be changed and can run reprocess feeders without having to edit the rule.
lotsaram wrote:Yes but there is another "hardcoded array notation" for feeders which is supported on the right hand side of a rule. You can just separate the items you want to feed with a comma.Wim Gielis wrote:{ } is supported on the left hand side of the feeder or rule, but not on the right hand side.
e.g.
[A] => , [C], [D];
or
[A] => , DB(), DB(), ....
You are right.
It's good to have the various ways summarized in this topic.
