Ragged Hierachy
aravind.cgns
OLAP Product: Cognos Tm1
Version: 10.2,11
Ragged Hierachy
Post by aravind.cgns »
Hi Guys,
I am trying to create a ragged hierarchy using performance modeler TI Process.My datasource is a file. i have multiple columns in the source file, there is a column named "Sub Parent Name" which has values and blank values in it. The succeding elements of "Sub Parent Name" in source file are "Customer Code" and "Customer Dimension". i am trying to create a ragged hierarchy in such a way that whenever there are blank values for "Sub Parent Name" it has to display only the "Customer Name". But the TIP is creating the dimension which is dispaying both "customer code" and "Customer Name" whenever it encounters blank for "Sub Parent Name" in source file.
Please suggest me is it possible to achieve this??
Please find the attachments for more info
Aravind
Ragged Hierarchy.png (21.81 KiB) Viewed 4991 times
Ragged Hierarchy.xlsx
(9.89 KiB) Downloaded 344 times
Re: Ragged Hierachy
You should post your TI code rather than the dimension. The TI code will be where the issue is.
If you are using the TI wizard code to generate the dimension then it will not cope with a ragged structure an you'll need to hand craft the script yourself.
aravind.cgns
Version: 10.2,11
Re: Ragged Hierachy
Steve,
Thanks for the reply, Pls find the attached TI Code
Ragged Hierarchy TI Code.txt
(5.51 KiB) Downloaded 392 times
dr.nybble
Excel Version: Excel 2007
Re: Ragged Hierachy
Post by dr.nybble »
The Guided Import wizard will generate TI to import ragged structures (just need to check the right box). In fact after reviewing your TI it appears you are using this.
It sounds like you are trying to get a view of your dimension that is not possible in TM1?
Each element in TM1 must be uniquely named in the dimension -- hence the strategy used by the generated TI to name the "filler" elements in the ragged structure.
aravind.cgns
Version: 10.2,11
Re: Ragged Hierachy
Thanks for the reply nybble, I have created "Ragged Hierarchy" using Guided Import but could not meet my requirement. Could do u guide me like where to create these "Filler" elements.
Thanks in Advance,
Aravind
Re: Ragged Hierachy
Apologies for the incorrect info, I've not really used the wizards in PM, I'd assumed the same as Perspectives.
