SecAdmin + TM1Web Applications
RJ!
Post by RJ! »
I have been trying to create something in TM1Web to allow our SecurityAdmin team to be able to update Client data via an Excel Template & stored as an Application.
During my testing as DataAdmin, all works fine, if test as any Client that has any group access other than SecurityAdmin, its still all good.
As soon as I try to access the Application on TM1Web when I use a Client with SecurityAdmin, I get the error "Failed to open the target workbook as the file does not exist."
Our SecurityAdmin team are in another Country so there is a decent performance upgrade if we can migrate to a TM1Web based process.
Is there a Security setting that I'm missing that needs to be updated or is SecurityAdmin group unable to use TM1Web templates?
Re: SecAdmin + TM1Web Applications
If these people are members of SecurityAdmin group and nothing else then all they can see is security cubes. Nothing else. Including application tree objects.
RJ!
Post by RJ! »
Thanks Lotsaram.
Even when the user has access to other "User" type groups, we were still getting this issue.
I've assumed that this is a limitation put on SecurityAdmin users so have created a new Group SecurityMaintenance & only gave that group access to the SecAdmin Application in TM1Web + the Process we created to Add/Delete/Update users.
It's working as expected.
If I ever get time, I might play with a Web Form using REST to see if that is also a possibility to update Client data via that method.
