no available TM1 servers in the drop down (TM1 web)
vshepeleva
Excel Version: 2008
Post by vshepeleva »
I have 2 TM1 servers running. I can access them from Architect and Performance Modeler. But in the TM1 web in the drop down they are not available (Drop down is empty).
Does anybody know why?
Thank you!
Re: no available TM1 servers in the drop down (TM1 web)
Does the list come up blank when you connect whilst on the server itself I.e. Http://localhost:9510/tm1web
Have you supplied an admin host if application server is running on a different server to the TM1 instance?
BR, George.
Elessar
OLAP Product: PA 2
Version: 2.0.9
Post by Elessar »
This can be a brower problem. Try using another
vshepeleva wrote:Hi,
Thank you!
Are you using Chrome? With Chrome you need to use the down arrow on the keyboard to get the dropdown, the mouse click doesn't work. :lol:
lotsaram wrote:Are you using Chrome? With Chrome you need to use the down arrow on the keyboard to get the dropdown, the mouse click doesn't work. :lol:
I always use Chrome and I never saw this one but I will remember it :-)
vshepeleva
Excel Version: 2008
gtonkin wrote:Does the list come up blank when you connect whilst on the server itself I.e. Http://localhost:9510/tm1web
List is blank on the main tm1 web page - Http://localhost:9510/tm1web.
It is all running on one server.
vshepeleva
Excel Version: 2008
Elessar wrote:This can be a brower problem. Try using another
I tried Chrome, Firefox and IE - same empty drop down everywhere.
Has it worked at all since the SSL update was carried out? There are a couple of TM1 specific steps for TM1 web and from memory they were at the very end of the list of instructions for 10.2.2.
Did it work before the SSL update?
Can you share the contents of the web config file? Does it have a named adminhost in it etc.
vshepeleva
Excel Version: 2008
I attached tm1 web config file.
AdminHost is defined. I also tried to use the full domain name of the admin host - like servername.domain.com but it still doesn't work.
I don't know if it worked before SSL update because we never tried to use it.
Thanks for your help!
tm1web_config.xml
(6.43 KiB) Downloaded 848 times
vshepeleva
Excel Version: 2008
We made it work.
Thanks to everybody ho replied! :)
vshepeleva wrote:We made it work.
Glad to hear you got it working. What was the issue? It could be useful to others who encounter the same problem. Was it SSL related?
dpando
OLAP Product: 1.1.1.1.1
Excel Version: 1
Post by dpando »
Hi everyone,
I faced the same issue and I solved it following the instructions here http://www-01.ibm.com/support/docview.w ... wg21991546
So the problem is related to the SSL Certs. I hope this helps you.
