Has anyone encountered the following error when trying opening a dimension subset:
tm1 unable to locate the registered public dimension or subset
After doing this server shuts down.
When the server is switched on again and I attempt to open the same subset it opens fine!
cheers, Mark
Problem opening subset
- Version: 10.1.1
- Excel Version: Excel 2010
Re: Problem opening subset
Think I have got to the bottom of this, basically the subset in question was created by SubsetCreatebyMDX and the consolidated element that was used in the MDX no longer exists.
I have now made the dimension build include delete and rebuild the subsets. None of which are used in public views.
