TM1Web can not get TM1 Server after the SSL upgrade
kiss351523
Version: 9.5
Excel Version: 2007 and 2003
Post by kiss351523 »
Dear All,
In accordance with the IBM document, the upgrade of the SSL, i can log in to server througth the Achitect, but there is a problem, access to TM1Web, can not get any TM1 Server in the droplist.
TM1 Version : 10.1
OS: Win2003
Web is IIS
Tks for all your help!!!!
Re: TM1Web can not get TM1 Server after the SSL upgrade
please confirm the version of TM1 you are experiencing this issue on.
BR, George.
kiss351523
Version: 9.5
gtonkin wrote:please confirm the version of TM1 you are experiencing this issue on.
oh TM1 version:10.1, thanks.
dsproffitt
OLAP Product: All of them
Version: All of them
Excel Version: 2003 -2013
Post by dsproffitt »
Have you added the certs to
1) Tomcat folder
2) Java keystore
3) Windows Keystore
HAve you recycled the Tomcat working directory?
dsproffitt wrote:Have you added the certs to
1) Tomcat folder
Isn't 10.1 still on IIS? I thought that the move to Tomcat came at 10.2. (Which is why I thought it odd that there was an instruction about Tomcat in the 9.5.x manual update instructions.)
Can you update your profile, please? (Via the User Control Panel that drops down from your name at the top right.) The main reason for having that field is so that people don't need to ask that question. Thanks.
Might be wrong but I though 10.1 web is IIS but tomcat was used for some of the contributor stuff.
AFAIK, you just need to run the following from the command prompt, as admininistrator, in the SSL folder after stopping services and replacing the certifcates with the new ones.
importsslcert.exe -remove
importsslcert.exe
There is a lot more waffle in the IBM doc but not relevant.
BR, George.
gtonkin wrote:AFAIK, you just need to run the following from the command prompt, as admininistrator, in the SSL folder after stopping services and replacing the certifcates with the new ones.
importsslcert.exe
That's correct, but if you don't do it then you won't be able to connect with Architect either. Yet the original poster claims that the latter is possible and it's only Web that isn't showing the list of servers.
Restarting the Web Publishing Service wouldn't be an entirely bad idea to see whether that rectifies it. I didn't explicitly do it but I rebooted the physical servers as a precaution and because they were overdue for it anyway, which amounted to the same thing. It doesn't cost anything to give it a shot.
declanr wrote:Might be wrong but I though 10.1 web is IIS but tomcat was used for some of the contributor stuff.
I too may be wrong but think they piloted Ops Console on java on 10.1, so potentially this would require some update if configured and in use.
BR, George.
dsproffitt
Alan Kirk wrote:Isn't 10.1 still on IIS? I thought that the move to Tomcat came at 10.2. (Which is why I thought it odd that there was an instruction about Tomcat in the 9.5.x manual update instructions.)
It did .. apologies .. Must remember to read the WHOLE post .. :|
kiss351523
Version: 9.5
I tried a variety of ways, still can not get the server list, very sadddddddddd :( :( :( :( :( :(
