I have a usual requirement in an OPEX cube when a user selects a Cost Center from the title dimension, only the relevant Expense lines should appear on the rows. We have done this many times in Web an Perspectives, worked fine. There is a small parameter cube with Cost Centers and Expenses, put a 1 to the relevant combinations, then use a subset like this in the planning cube, while having CCs on title, Expenses on rows:
{FILTER(TM1FILTERBYLEVEL(TM1SUBSETALL([Accounts_OPEX_PLAN]) , 0) , [PLAN_Param_CCToGL].([CostCenters_OPEX].CURRENTMEMBER,[StrNum].[nValue]) = 1)}
It seems CAFE ignores the "[CostCenters_OPEX].CURRENTMEMBER" part of the subset, and returns those Expenses of which Sum is 1 in the parameter cube => so those expenses that are assigned to one and only one Cost center, independently from the Cost center selection on the title.
Any idea of a quick workaround? Same results but different mdx code?
Thank you!
Matyas
CurrentMember in CAFE
- paulsimon
- Version: PA 2.0.5
Re: CurrentMember in CAFE
HI
I would suggest creating a dimension from your cube with consolidations for each Cost Centre and base level elements of the relevant Expense codes. Then you don't even need MDX. You can use a simple list with ELCOMP.
mvaspal
- OLAP Product: tm1
- Version: 10 2 2 - 2.0.5
Thanks Paul!
Actually, that is one of my main points to consider if I want to use one merged, or two dimensions, found some pros/cons for both. If I understand correctly your suggestion means the one dimension approach.
- paulsimon
- Version: PA 2.0.5
No I am not suggesting that you need to convert your cube to a single combined dimension. I was suggesting that you create a dimension that is not used in any cubes and that you just use this to drive the dependency between the two dimensions for your second drop down box.
- PavoGa
- Excel Version: 2013 PAW
{FILTER(TM1FILTERBYLEVEL(TM1SUBSETALL([Accounts_OPEX_PLAN]) , 0) , [PLAN_Param_CCToGL].([CostCenters_OPEX].CURRENTMEMBER,[StrNum].[nValue]) = 1)}Ty
Cleveland, TN
Cleveland, TN
mvaspal
- OLAP Product: tm1
Not in CAFE unfortunatelyIt will automatically filter it for the context of the title dimension, the cost center selected.
mvaspal
- OLAP Product: tm1
Seems to be a bug, if I open the subset editor in CAFE, click on the MDX icon, and amend the subset by just adding a simple space, it starts working.
So I think it won't be related to CurrentMember, much more how CAFE renders the dynamic subset, although not sure yet what kind of mdx expressions/formulas are impacted, if it is not only CurrentMember
Ticket opened, I will post the APAR nr here.
