TM1 x64 install
jonathan.d
Version: TM1 9.4 MR1
TM1 x64 install
Post by jonathan.d »
On installing TM1 x64, I realised I do not have the usual options of Architect and Perspectives in windows 'start up'.
I looked into the 'bin' and 'bin32' folder, and cannot find any .xla files which would act as plugins.
Also, the tm1a.exe file doesn't seem to exist.
Is this done on purpose or have I missed out on something?
Re: TM1 x64 install
jonathan.d wrote:Hi All,
Did you do a custom install? I haven't used 64 bit TM1, but I know that in some versions the Architect client isn't installed in the default installation; you have to manually select it in a custom install.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: TM1 x64 install
Post by Michel Zijlema »
Hi Jonathan,
The x64 install package installs the 64-bit components. Architect and Perspectives are 32-bit applications and need to be installed using the x86 package.
Michel
jonathan.d
Re: TM1 x64 install
Issue resolved.
Found documentation stating that there aren't any 64bit client applications available.
Thanks for the prompt reply!
