I want to import pdf document into tm1 server, and after put link to this document in tm1 websheet.
Could anybody help me?
Link to PDF in tm1web
BariAbdul
- Version: PAW 2.0.8
- Excel Version: 2019
Re: Link to PDF in tm1web
You can display a link to a pdf document in TM1Web as per below IBM doc,If I am understand correctly what you are after:
http://www-01.ibm.com/support/docview.w ... wg21454744 Thanks
motylfx
- OLAP Product: cognos tm1
- Version: 10.2
I haven't write, that I'm using 10.2 version of cognos (srorry) - in 10.2 there isn't iis.
TM1 Web doesn't use IIS anymore but that doesn't mean the technique isn't still valid.motylfx wrote:I haven't write, that I'm using 10.2 version of cognos (srorry) - in 10.2 there isn't iis.
