Need help with SUBDEFINE. Could not find anything that was solved. Please help.
initm1
OLAP Product: Microsoft
Excel Version: OFFICE365
Post by initm1 »
Hi everyone, I am trying to make SUBDEFINE function work for me.
I have tried multiple ways but couldn't make it work. Please help. below is what I have.
thanks in advance.
Sub testSubset()
Dim x
ThisWorkbook.Activate
ActiveSheet.Activate
x = Application.Run("SUBDEFINE", "dev1.dev.boa.com:HeadCount", "testVBss", "A1:A10")
Debug.Print x
End Sub
TM1.Prespectives.Win7.Office365,Excel2016,Excel2010
Paul Segal
Version: TM1 11 and up
Re: Need help with SUBDEFINE. Could not find anything that was solved. Please help.
Post by Paul Segal »
Try replacing "A1:A10" with
Worksheets("Worksheetname").Range("A1:A10")
The whole thing should read
 x = Application.Run("SUBDEFINE", "dev1.dev.boa.com:HeadCount", "testVBss", Worksheets("Worksheetname".Range("A1:10"))
Obviously, replace Worksheetname with the name of your worksheet.
Paul
initm1
Post by initm1 »
Hi Paul, I tried the same but still wont work. x returns false. I verified it in Cube Viewer too.
Is there something I could be missing or has the admin disabled this feature? any way to find the reason?
Are you connected to the server, either with N_Connect or through the front end?
Can you get simple functions like DIMIX to work?
The VBA TM1 client also tends to have an issue with the reconnection of broken connections so for example if your connection expires and then you re log, the front end will work but the VBA doesn't.
initm1
Post by initm1 »
Okay thank you. Let me play around with connection and see if I can make it work. Will post back tomorrow. Good day!
paulsimon
Version: PA 2.0.5
Post by paulsimon »
Also try using a named range - simpler than A1:A10
