Problem updating cube cells using TM1 REST API
Alexander Jell
OLAP Product: TM 1
Post by Alexander Jell »
I recently tried to update 1 cell within a cube using the TM1 REST API. I am using a MDX Statement to get the cellset ID. Here is the mdx
{"MDX":"SELECT {[ADDiN_DIMS].[DIM1]} on 0 from C_ADDIN2 where ([}Clients].[Admin],[REPORTS_FEBR].[GEN],[ADDIN_PARA].[DIM_LABEL] )"}
This statement always gives me the correct cell and cell value.
Here is the server response:
{"@odata.context":"$metadata#Cellsets(Cells)/$entity","ID":"XDMZY28CAIBwAAAg","Cells":[{"Ordinal":0,"Value":"SZENARIEN","FormattedValue":"SZENARIEN"}]}
Now. If i try to do a PATCH statement on this cellset, i get the error: {"error":{"code":"","message":"SystemValueInvalid"}}
This is my PATCH request:
PATCH /api/v1/Cellsets('XDMZY28CAIBwAAAg')/Cells
"Ordinal":0,
"Value":"Test"
Can anyone explain why i get this error, or what could cause this problem.
Thanks in advance.
Best regards
Alexander Jell
BrianL
Version: 9.5.2 10.1 10.2 PA2
Re: Problem updating cube cells using TM1 REST API
Post by BrianL »
At a quick glance I'd assume it's because you are sending a single value and not an array containing a single value in the request body.
http://www.ibm.com/support/knowledgecen ... ll?lang=en
