Distinguish String elements in an MDX
Hello all,
As the title of the topic says, does anyone know how to distinguish string elements from numeric elements in an MDX-statement ?
I would like to, for example, have an MDX-driven subset on a dimension, that filters out all lowest-level numeric elements - no string elements.
I checked the properties, CurrentMember and so on, but could not find anything useful. Maybe it's because TM1 does not expose this information in its application of MDX statements ?
Thanks !
Re: Distinguish String elements in an MDX
Not aware of any mdx filter function for it but I can't say I have ever tried; if there was a function I would assume it must be a TM1 specific function as opposed to standard MDX.
Suppose to get around it you could have a TI populate an attribute on the dim that just places the result of a DType in the attribute. Then filter that in the MDX.
Thank you Declan. You confirm my findings.
The purpose is to only use MDX, such that the dynamic subset responds to changing dimension elements/hierarchies without running any additional TI process.
I would also like to avoid a rule with Dtype.
Thanks !
Hi Wim,
I generally ensure all my N and C measures have formats configured with comma, percentage etc. etc. The remaining measures would then generally be the strings.
I then use MDX as follows to select them:
FILTER([Measures].Members, [Measures].Currentmember.Properties("Format") = "")
Obviously not fool-proof but in your case I get the feeling you are meticulous so should work.
BR, George.
Hello gtonkin,
Thanks, it's 1 step in the good direction, I hadn't thought of that.
I'll be looking for other solutions and keep this one in mind.
Wim
Wim Gielis wrote:Thank you Declan. You confirm my findings.
Thanks !
Why don't you want to set an Attribute with DType?
ardi
OLAP Product: tm1, cognos bi
Post by ardi »
I have done this with a Text Attribute Element_Type and in the TI that loads my measures dimension, I populate this attribute, but you can have a Rule to automatically maintain that attribute. Basically same this as lotsaram is proposing.
Ardian Alikaj
Hello all,
Thanks for the replies.
The scenario is as follows: I would like to use TI to create an MDX-driven subset to gather orphan elements.
I could do this in 1 dimension, or all dimensions of a certain cube, or all application dimensions, ...
I would prefer to only do the SubsetCreateByMDX and that's it. No additional attributes dimensions and cubes, no rules, and so on.
Whenever the dimension changes, the subset should update (as is usual with dynamic subsets :) ) without running the TI process again.
And by any chance... a method that is fool-proof :D
Wim
Cannot do fool-proof but may have last resort for you as follows:
FILTER(
FILTER(
FILTER( [Measures].Members,
COUNT([Measures].CurrentMember.Ancestors)=0),
COUNT([Measures].CurrentMember.Children)=0),
[Measures].Currentmember.Properties("Format") <> "")
OR
FILTER(
FILTER(
[Measures].CurrentMember.Parent.Name=""),
I have not been able to establish what, if any Property could be used to derive the DType and filter on Simple, Consolidated or String - may someone else has stumbled onto this and can share then you would have your solution.
BR, George.
ardi
Post by ardi »
Wim Gielis wrote:Hello all,
Wim
By Orphan Elements you mean leaf numeric elements that do not have a parent? In that case you can write an MDX to do that, but if you want to distinguish String Elements from N elements that I dont think you can achieve it without additional attributes.
Ardian Alikaj
ardi wrote:By Orphan Elements you mean leaf numeric elements that do not have a parent? In that case you can write an MDX to do that, but if you want to distinguish String Elements from N elements that I dont think you can achieve it without additional attributes.
That's indeed the subject of this topic :)
I had hoped for a reliable MDX-way of separating n and s type elements.
Trevor MacPherson
Excel Version: None
Post by Trevor MacPherson »
I might be missing something, but if the dimension had at least one cube that it was used in (as the format dimension), then an expression should demonstrate the strings like so:
EXCEPT({TM1SUBSETALL( [MyDim] )},{ FILTER( {TM1SUBSETALL( [MyDim] )}, [MyCube].[MyDim].CurrentMember<3.402823E38 AND [MyCube].[MyDim].CurrentMember>-3.402823E38)})
It doesn't matter if the cube is populated or not.
I haven't tested thoroughly, but it works in the small sample of cubes I've tried.
And then George Tonkin came with the solution ! :!: :D
Filter( TM1SubsetAll( [Revenue_Msr] ), [Revenue_Msr].CurrentMember.Properties("ELEMENT_TYPE")="1")
1 = N type
2 = S type
3 = C type
Mark RMBC
Version: 10.1.1
Excel Version: Excel 2010
Post by Mark RMBC »
Talk about dogged persistence, an example to us all!
I was then wondering if Element_Weight would return anything but doesn't!
I did get Element_Index to work,
so for example,
Filter( TM1SubsetAll( [Revenue_Msr] ), [Revenue_Msr].CurrentMember.Properties("ELEMENT_INDEX")>"2")
regards,
Mark
Try something like this Mark:
FILTER(TM1SubsetAll([account1]),
[account1].currentmember.properties("MEMBER_WEIGHT")<>"1.000000")
or
FILTER(TM1DrillDownMember(TM1SubsetAll([test]),ALL,Recursive),
StrToValue([test].currentmember.properties("MEMBER_WEIGHT"))=-1)
BR, George.
Wim Gielis wrote: Thu Oct 21, 2021 9:04 pm And then George Tonkin came with the solution ! :!: :D
1 = N type
2 = S type
3 = C type
I wish there was a like or +1 button. I never knew this.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
Hi George,
The Member_Weight does work, how long has that been around?
I obviously need to pay more attention ;)
regards,
Mark
Mark RMBC wrote: Fri Oct 22, 2021 8:27 am Hi George,
regards,
Mark
Probably since forever but undocumented like many other functions and properties unfortunately.
BR, George.
Mark RMBC
Version: 10.1.1
Post by Mark RMBC »
Cheers George.
I even asked IBM about this, re this forum discussion:
viewtopic.php?t=14986
It is even undocumented to them!
Good work for joining the dots 👏
lotsaram wrote: Fri Oct 22, 2021 8:12 am
1 = N type
2 = S type
3 = C type
Credits to George
