Optimistic by nature, I have loaded this RFE:
Description: User folders within the TM1 Data folder create a lot of clutter and there should be a way to separate these in a similar manner to the Logs / RawStore directories.
Use Case: Administrator would configure TM1S.CFG to set UserDirectories for example to a location other than the data directory. All user folders and related private views/subsets would then be written there.
Business Case: Removes clutter, more easily managed source code/system objects, allow better disk management and maintenance, allows anti-virus to be configured less explicitly etc. etc.
Please vote if you see the benefit of this. If you have further justification that I can add, please tell me.
Thanks, George.
