Some elements in a dimension is missing attibutes randomly
u970700
Version: PAL 2.0.9.2
Excel Version: Excel 2016
Post by u970700 »
I'm a little stumped with this issue, where some element attributes in a dimension would not be populated. This issue appears to occur randomly and sporadically throughout the hierarchy, as I can't seem to find a definitive pattern that would cause this. [1_wo_missing_attibute.JPG]
The weird thing is, the source data has all the available data, and the TI process that refresh the dimension completes without errors. [2_wo_db_source.JPG]
Did a few tests with the TI queries without success, so I updated the TI process' source query to only bring back the subset of elements with the issue, and viola the dimension refreshed with all attributes populated for this subset!
Weirder still, after doing the above and reverting the TI process back to the original SQL and reran the process, the elements with missing attributes are now fixed! But there are still elements with missing attributes further down the hierarchy. [3_wo_fixed.JPG]
The dimension itself has about 230k+ elements, which shouldn't really be an issue? As there are other dimensions with 1m+ elements and TM1 populated the dimension attributes OK.
I've also attached the TI process, the Data tab that populate the attributes is fairly standard.
Has anyone had similar issue like this before? I couldn't find anything in the forum...so any help or pointers would be greatly appreciated!
Cheers.
Ray
Prolog:
# Declare Variables
cDimName='Work Order';
UnkWO = 'Unknown WO';
vALL='ALL WORK ORDERS';
# Unwind the dimension
ExecuteProcess('_System - Unwind Dimension', 'pDimName', cDimName);
# Insert top parent and unknown element
IF(DIMIX(cDimName, vALL)=0);
  DIMENSIONELEMENTINSERT(cDimName,'',vALL,'C');
ENDIF;
IF(DIMIX(cDimName, UnkWO)=0);
  DIMENSIONELEMENTINSERT(cDimName, '', UnkWO, 'N');
ENDIF;
  DIMENSIONELEMENTCOMPONENTADD(cDimName, vALL, UnkWO, 1);
Metadata:
  IF(DIMIX(cDimName, vWONUM)=0);
    DIMENSIONELEMENTINSERT(cDimName,'', vWONUM, 'N');
  ENDIF;
# RO hierarchy
# BU > Category > Work Type > Region > Service > Suburb
IF(vBU@='RO');
  IF(DIMIX(cDimName, vMaintDeptSuburb)=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vMaintDeptSuburb, 'C');
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vMaintDeptSuburb, vWONUM, 1);
  IF(DIMIX(cDimName, vHierarchyMaintDept)=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vHierarchyMaintDept, 'C');
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vHierarchyMaintDept, vMaintDeptSuburb, 1);
  IF(DIMIX(cDimName, vHierarchyRegion)=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vHierarchyRegion, 'C');
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vHierarchyRegion, vHierarchyMaintDept, 1);
  IF(DIMIX(cDimName, vHierarchyType )=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vHierarchyType, 'C');
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vHierarchyType, vHierarchyRegion, 1);
  IF(DIMIX(cDimName, vHierarchyCategory)=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vHierarchyCategory, 'C');
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vHierarchyCategory, vHierarchyType, 1);
  IF(DIMIX(cDimName, vBU)=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vBU, 'C');
  ENDIF;
ENDIF;
# Remaining BU hierarchy
IF(vBU@<>'RO');
  IF(DIMIX(cDimName, vHierarchySuburb)=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vHierarchySuburb, 'C');
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vHierarchySuburb, vWONUM, 1);
  IF(DIMIX(cDimName, vHierarchyNetwork)=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vHierarchyNetwork, 'C');
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vHierarchyNetwork, vHierarchySuburb, 1);
  IF(DIMIX(cDimName, vHierarchyService)=0);
    DIMENSIONELEMENTINSERT(cDimName, '', vHierarchyService, 'C');
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vHierarchyService, vHierarchyNetwork, 1);
  ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vHierarchyRegion, vHierarchyService, 1);
  ENDIF;
  ENDIF;
  ENDIF;
ENDIF;
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vBU, vHierarchyCategory, 1);
    DIMENSIONELEMENTCOMPONENTADD(cDimName, vALL, vBU, 1);
Data:
vAlias = vWONUM |' : '| vDESCRIPTION;
# Update dimension attributes
ATTRPUTS(vAlias, cDimName, vWONUM, 'Code and Description' );
ATTRPUTS(vLOCATION, cDimName, vWONUM, 'Location');
ATTRPUTS(vASSET, cDimName, vWONUM, 'Asset Number');
ATTRPUTS(vREGION, cDimName, vWONUM, 'Region');
ATTRPUTS(vSTATUS, cDimName, vWONUM, 'Status');
ATTRPUTS(vGL, cDimName, vWONUM, 'GL Account');
ATTRPUTS(vAssetGL, cDimName, vWONUM, 'Asset GL Account');
ATTRPUTS(vBU, cDimName, vWONUM, 'Business Unit');
ATTRPUTS(vService, cDimName, vWONUM, 'Service');
ATTRPUTS(vSuburb, cDimName, vWONUM, 'Suburb');
ATTRPUTS(vNetwork, cDimName, vWONUM, 'Network Service');
TM1 9.5.2 FP3, Windows 2008 R2 64bit, Excel 2003 SP3
Re: Some elements in a dimension is missing attibutes randomly
Hi Ray, seen a similar thing on 952 FP3 or so I was led to believe - turned out the server was actually running FP2.
Check the TM1Server.log for the build number and confirm by looking at the Product Version of tm1sd.exe in the BIN folder of your TM1 install.
Based on the reference here, you need to be on 9.5.20300.29580 for TM1 9.5.2 Fixpack 3 - 9.5.20300.29580
Hope it is as easy as a version issue! Good luck.
BR, George.
u970700
Post by u970700 »
Thanks gtonkin but it's definitely on FP3, as I'd upgraded it earlier this week...hoping it would resolve the issue.
Double checked just in case, the build number for both tm1sd.exe and tm1server.log is 9.5.20300.29580.
