Using VBA to connect to TM1 application
Re: Using VBA to connect to TM1 application
There is absolutely no reason that an Excel file, with TM1 formulas in it, would open faster without the TM1 add-in loaded versus with it loaded. If it takes longer with the add-in loaded it is because the formulas are being calced while the sheet is being opened. You may think that recalc is set to manual but you need to check this thread, http://www.tm1forum.com/viewtopic.php?f=3&t=1128&p=6372, to make sure this isn't what is happening to you.
				iansdigby
 - Version: 9 + 10 + Plan An
 - Excel Version: All
I am doing exactly waht smorgan is. Using a combination of techniques as advised herein by others, you should be able to get it going fairly quickly. Incude:
Screenupdating=false
Recalc mode=manual and do strategic calcs only where necessary
Create a new workbook for each iteration
Proper VIEW() functions for DBRW()
Here's my VBA code for the outer and inner loops (x200).
It uses a central error handler and a form to get the user choices, so adapt as needed. Maybe it'll help...
'Look down the hierarchy and create a PDF
'report for every N-level TM1 element
Public Function gbCreatePDFs(Optional ByVal bSelected As Boolean) As Boolean
    Const sSource As String = "gbCreatePDFs()"
    Dim bReturn As Boolean
    Dim rngCell As Range, lCalculation As Long
    Dim iPDFCount As Integer, iPDFCounter As Integer
    Dim frmPDF As FPDF
    On Error GoTo ErrorHandler
    bReturn = True
    lCalculation = Application.Calculation
    Application.Calculation = xlCalculationManual
    Application.ScreenUpdating = False
    'Test whether TM1 add-in is loaded
    Application.Run "TM1RECALC1"
    'If selected reports only, (passed boolean optionally),
    'show a form for user to select reports to create.
    'For each one selected, produce a new report.
    'Otherwise loop all elements.
    Set frmPDF = New FPDF
    With frmPDF
        'Populate the form list with elements to select from
        If Not .gbPopulateList() Then Err.Raise glHANDLED_ERROR
        .Show
        If .UserCancel Then
            Err.Raise glUSER_CANCEL
        Else
            'Grab the selections into a local array
            'arrSelectedReports = .Selections
            Set mrngCellsToTest = .SelectionRange
        End If
    End With
    wksMaster.Activate
    'Add a backslash to the output folder string if necessary.
    msOutputFolderPDF = wksControl.Range("PDFOutputFolder").Value
    msOutputFolderExcel = wksControl.Range("ExcelOutputFolder").Value
    If Right(msOutputFolderPDF, 1) <> "\" Then
        wksControl.Range("PDFOutputFolder").Value = msOutputFolderPDF & "\"
    End If
    'Get the number of PDFs so we can show progress to the user.
    iPDFCount = mrngCellsToTest.Rows.Count
    'Loop through cells and create pdfs where indicated.
    For Each rngCell In mrngCellsToTest.Cells
        iPDFCounter = iPDFCounter + 1
        Application.StatusBar = "Creating " & rngCell.Value & _
                              " PDF, " & iPDFCounter & " of " & iPDFCount & "..."
        'Select the CC item in the pick list.
        If Not mbCreatePDF(rngCell.Value) Then Err.Raise glHANDLED_ERROR
    Next rngCell
    'Report finished.
    MsgBox "Finished creating PDF reports.", vbInformation + vbOKOnly
ProcExit:
    gbCreatePDFs = bReturn
    'Restore environment.
    Application.Calculation = lCalculation
    Application.ScreenUpdating = True
    Application.StatusBar = ""
    Application.DisplayAlerts = True
    Exit Function
ErrorHandler:
    bReturn = False
    If Err.Number = 1004 Then
        MsgBox "Please check that you are logged in to TM1", vbExclamation + vbOKOnly, "TM1 Load Error"
    End If
    If gbCentralErrorHandler(msMODULE, sSource) Then
        Stop
        Resume
    Else
        Resume ProcExit
    End If
End Function
'CREATE A PDF REPORT FOR THE PASSED COST CENTRE
Private Function mbCreatePDF(ByVal sCostCentre As String) As Boolean
    Const sSource As String = "mbCreatePDF()"
    Dim bReturn As Boolean, wkbNew As Workbook, rngStart As Range
    bReturn = True
    'Enter the Cost Centre and recalculate.
    wksMaster.Activate
    wksMaster.Range("Expense_Cost_Centre").Value = sCostCentre
    Application.Run "tm1recalc1"
    'Only produce a report where there are some numbers.
    If Not mbAllCellsAreZero Then
        UnhideZeroRows
        'Copy the result to a new workbook, value copy everything,
        'then hide rows and export as PDF
        Set rngStart = wksMaster.Range("HideRowStart")
        'Create a new workbook
        wksMaster.UsedRange.Copy
        Set wkbNew = Workbooks.Add
        'Copy the whole of master
        With ActiveSheet
            .Paste
            'PasteSpecial to copy column widths
            .Range("A1").PasteSpecial Paste:=xlPasteColumnWidths, Operation:=xlNone, SkipBlanks _
        :=False, Transpose:=False
            'PasteSpecial to remove formulas
            .UsedRange.Copy
            .Range("A1").PasteSpecial Paste:=xlPasteValues
            'Copy the hiderow start range
            rngStart.Copy _
                    Destination:=.Range(Mid(rngStart.Name.RefersTo, 9, 10))
            .Range(Mid(rngStart.Name.RefersTo, 9, 10)).Name = "HideRowStart"
            'Hide the check total row
            .Rows(gs_ROW_CHECKTOTAL).Hidden = True
            'Delete the TM1 header area.
            .Rows(gs_ROWS_HEADER).Delete Shift:=xlUp
            'Hide blank/zero rows
            If Not gbHideZeroRows(False) Then Err.Raise glHANDLED_ERROR
            'Set the print parameters.
            With .PageSetup
                .CenterFooter = "Page &P of &N"
                .Orientation = xlLandscape
                .Zoom = False
                .FitToPagesWide = 1
                .FitToPagesTall = 20
                .PrintTitleRows = gs_ROWS_PRINT_TITLES
            End With
            'Produce PDF
            .ExportAsFixedFormat _
                    Type:=xlTypePDF, _
                    Filename:=wksControl.Range("PDFOutputFolder").Value & Replace(sCostCentre, "/", "-") & ".pdf"
        End With
        Application.DisplayAlerts = False
        wkbNew.Saved = True
        wkbNew.Close SaveChanges:=False
    End If
ProcExit:
    Set wkbNew = Nothing
    mbCreatePDF = bReturn
    Exit Function
ErrorHandler:
    bReturn = False
        Stop
        Resume
    Else
        Resume ProcExit
    End If
End Function
				TM1nowhere
 - OLAP Product: TM1, Jedox/Palo, Essbase
 - Version: 10.1
thought this post would contain the solution to my problem... that wasn't the case... still found a solution...
For anyone having issues connecting Excel to TM1 via VBA, check out this: http://www-01.ibm.com/support/docview.w ... wg21959177
