I have a problem with TM1 Applications. I have just installed TM1 10.2.2, and everything else works fine except TM1 Applications. When I'm at the same server where my installation is, everything works fine (I can sign in both localhost:9510/pmpsvc and tm1:9510/pmpsvc). When I try to use applications in the same network but when I'm not in that particular server, I can still sign in to Applications but I can't find any applications there. TM1 Web works fine at the same time.
I am also missing "Administer IBM Cognos TM1 Applications" icon from my toolbar, if I try to login somewhere else than from the computer where my TM1 installation is.
If I click "Manage Jobs for IBM Cognos TM1 Applications", even if I don't see any applications available,I can find that my application is deployed and everything seems to be ok.
I'm using localhost as Admin Host, does it have something to do with this? I appreciate any help with this. Thank you!
