Multiple CSV Sources data Load
DPTM1Guy
Version: 9.5.2
Excel Version: 2008
Post by DPTM1Guy »
I am having 3-4 .csv as source files and want to load all of them into a single cube using single TI process(without merging as single flat file)
Is it possible?
DP
BariAbdul
Version: PAW 2.0.8
Excel Version: 2019
Re: Multiple CSV Sources data Load
Post by BariAbdul »
I am afraid,You can't do it within one TI unless it is master TI calling other processes by ExecuteProcess have it as chore,Please see below post:
http://www.tm1forum.com/viewtopic.php?f=3&t=5984
http://www.tm1forum.com/viewtopic.php?f=3&t=8381 Thanks
As long as the files are in the same format you can use the same TI to load them; just use the datasource functions to specify which file to use at run time.
You can either use a master process that passes the file name each time or call the process itself from its own epilog just passing the "next" file name; if all files have the same prefix you ca use the wildcard search function in the given folder to just keep finding the next one until you've got them all.
Edit - remember if there is a zero out etc you may want to wrap it in an if statement so it only zeros on the first run.
DPTM1Guy
Version: 9.5.2
Excel Version: 2008
Post by DPTM1Guy »
Thanks for the quick response Bari :-)
Regards, DP
DPTM1Guy
Version: 9.5.2
Excel Version: 2008
Post by DPTM1Guy »
Thanks Declan.
Regards, DP
