I have one simple question. I have a table in Active Form and I would like to know if it is possible to have second row with other variable than first. I use function DBRW. First parametr is a cube, second is the same like in every row, but the last one is dynamic and is taken according to apropriate line. I would like to have two dynamic parameters in one DBRW function but, it doesn't work in tm1 application. It is possible?
Please ask if you don't understand issue.
| 2013 | 2014 | |
| E1 | DBRW( cube, E1,P1,2013) | DBRW(cube, E1, P1, 2014) |
| E2 | DBRW( cube, E2,P2,2013) | DBRW(cube, E2, P2, 2014) |
E1, E2 - elements of dimension 1
P1, P2 - elements of dimension 2
2013, 2014 - elements of dimension 3
All elements are described as reference to cells.
When I recalculate form it looks like this:
| 2013 | 2014 | |
| E1 | NumValue | NumValue |
| E2 |
