Attribute Rules
John Hobson
OLAP Product: Any
Version: 1.0
Excel Version: 2020
Attribute Rules
Post by John Hobson »
Should I be able to create a rule in an attribute cube as follows?
['LeadTimeWeeks'] = N: ['LeadTimeDays'] \ 7;
['LeadTimeWeeks'] = C: 0;
['LeadTimeDays'] = C: 0;
All 3 targets are numeric attributes.
The rule appears to compile from Excel
The rule is clearly present in the rule editor
The target cells are white and empty in cube viewer. :(
Is there something about attribute cubes that stops you performing calculations like this?
John
John Hobson
The Planning Factory
mattgoff
Version: 10.2.2.6
Excel Version: O365
Re: Attribute Rules
Post by mattgoff »
John Hobson wrote:Is there something about attribute cubes that stops you performing calculations like this?
Yup, I believe cells in attribute cubes behave like strings, no matter the element type. If you need to do math, make a regular cube instead of using attributes.
Matt
John Hobson
OLAP Product: Any
Version: 1.0
Excel Version: 2020
Re: Attribute Rules
Cheers Matt - I had a vague memory of that but it's good to have it confirmed.
It does beg the questions "Why?" and "Why have a numeric attribute type at all?" though.
I always thought that attribute cubes were just normal 2d cubes that were exposed to the subset editor, but maybe there's a good reason for treating them differently as regards rules?
John Hobson
Steve Vincent
Version: 10.2.2 FP1
Re: Attribute Rules
Post by Steve Vincent »
probably the same good reason that rules work differently when run as a server and as a local host ;)
Eric
Version: 9.4
Re: Attribute Rules
Post by Eric »
I came across the same problem. The consensus was Attribute cubes are to hold descriptive data, not information. As pointed out, only "string" data even if it is a numeric. That is part of the reason why numeric values do not consolidate in an attribute cube. The only reason it allows for string and numeric in an attribute is so you can reference the attribute in a rule and not have to suck up memory converting every attribute cell to numeric aka NUMBR().
HTH
Eric
Martin Ryan
Re: Attribute Rules
Post by Martin Ryan »
If you use the "DTYPE" formula in Excel (or in VBA anyway, where I tried it) on an element in an attribute dimension it returns something other than "S" or "N". It returns either "AS" and "AN".
Effectively numeric attributes are a crossover between strings and numeric, so they're neither and both.
Martin
Jodi Ryan Family Lawyer
PavoGa
Excel Version: 2013 PAW
Re: Attribute Rules
Post by PavoGa »
You can have a rule on an attribute cube update numeric attributes properly by not using the = N: syntax.
['LeadTimeWeeks'] = ['LeadTimeDays'] \ 7;
Not sure how to deal with consolidations, I did not have to work that out, but I can get the above to work on simple elements.
Ty
Ty
Cleveland, TN
