As a self-leaner, I am little confused about the port.
The normal ports 5495,5498,80,9300,9510,9513,9655 in version 10.2.2, I can directly read from the configuration management.
But some ports is invisible.We assumed that client connect to server, if the server close all ports in a company and only open the port that may TM1 use. So we should known all the ports need to be open.
So are there any TM1 document introduce all the function of the ports?
By the way, what about the port of performance management? This is what I currently don't know.
Thanks a lot.
